My first set: Philco 40-180
Happy for you Eric, it is amazing what a good cleaning can do. A little finish restorer and the scratches will virtually disappear. I find nothing wrong with a finish not being perfect on an old radio. It should not be, I like the little lady to show some of her age.
Jerry
My first set: Philco 40-180 - by EricS - 08-22-2013, 04:03 PM
RE: My first set: Philco 40-180 - by codefox1 - 08-22-2013, 06:19 PM
RE: My first set: Philco 40-180 - by Jamie - 08-22-2013, 07:25 PM
RE: My first set: Philco 40-180 - by EricS - 08-22-2013, 09:13 PM
RE: My first set: Philco 40-180 - by EricS - 08-22-2013, 09:36 PM
RE: My first set: Philco 40-180 - by Arran - 08-23-2013, 12:22 AM
RE: My first set: Philco 40-180 - by EricS - 08-23-2013, 10:10 AM
RE: My first set: Philco 40-180 - by EricS - 08-23-2013, 05:26 PM
RE: My first set: Philco 40-180 - by Jamie - 08-23-2013, 07:18 PM
RE: My first set: Philco 40-180 - by EricS - 08-23-2013, 09:49 PM
RE: My first set: Philco 40-180 - by jerryhawthorne - 08-23-2013, 10:49 PM
RE: My first set: Philco 40-180 - by EricS - 08-24-2013, 05:55 PM
RE: My first set: Philco 40-180 - by EricS - 08-24-2013, 07:56 PM
RE: My first set: Philco 40-180 - by codefox1 - 08-25-2013, 04:03 PM
RE: My first set: Philco 40-180 - by EricS - 08-25-2013, 08:59 PM
RE: My first set: Philco 40-180 - by EricS - 08-26-2013, 01:56 PM
RE: My first set: Philco 40-180 - by EricS - 08-26-2013, 07:09 PM
RE: My first set: Philco 40-180 - by EricS - 08-26-2013, 07:34 PM
RE: My first set: Philco 40-180 - by Jamie - 08-26-2013, 08:12 PM
RE: My first set: Philco 40-180 - by EricS - 08-27-2013, 09:58 AM
RE: My first set: Philco 40-180 - by EricS - 08-29-2013, 11:24 AM
RE: My first set: Philco 40-180 - by EricS - 09-03-2013, 04:41 PM
There are currently 4543 online users. [Complete List]
» 3 Member(s) | 4540 Guest(s)
