Philco 39-55 Mystery
Not that I am aware of. You would have to be good at molding plastic.
Right now, the only answer that I am aware of is to obtain the thumbwheels from a junker set.
Too bad...a 39-36 chassis sold today on eBay for only $1. Of course its thumbwheels might have been stripped also...one never knows.
Maybe this is a job for one of the people who can duplicate parts (Old-Time Replications or Renovated Radios)? There may be a potential market here...
Philco 39-55 Mystery - by Robert - 03-01-2008, 07:41 PM
[No subject] - by Ron Ramirez - 03-01-2008, 08:56 PM
[No subject] - by Robert - 03-02-2008, 04:25 PM
[No subject] - by gary rabbitt - 03-04-2008, 02:46 PM
[No subject] - by Robert - 03-09-2008, 08:30 PM
[No subject] - by Chuck Schwark - 03-09-2008, 11:10 PM
[No subject] - by Robert - 03-09-2008, 11:14 PM
Philco 39-55 - by Doug Houston - 03-27-2008, 11:36 PM
[No subject] - by Ron Ramirez - 03-28-2008, 07:28 PM
Philco 91 Tuning Condenser
