Wireless RP-2 governor?
There was a discussion on old players running fast a few months ago. It was then pointed out indeed the motors used were voltage dependent to a certain degree. Lowering his A/C voltage on a variac brought the motor to proper speed. If I recall his line voltage was in the mid 120s. I was stunned! It was well explained in the thread, something to do with the motors not being synchronous as I recall but have since forgot.
Jerry
Edit: I found the discussion, look at the last couple posts on the first page.
http://antiqueradios.com/forums/viewtopi...able+speed
Wireless RP-2 governor? - by Skip - 08-24-2013, 11:58 AM
RE: Wireless RP-2 governor? - by morzh - 08-24-2013, 12:01 PM
RE: Wireless RP-2 governor? - by Skip - 08-24-2013, 12:09 PM
RE: Wireless RP-2 governor? - by Eric T - 08-24-2013, 12:40 PM
RE: Wireless RP-2 governor? - by BrendaAnnD - 08-24-2013, 01:45 PM
RE: Wireless RP-2 governor? - by jerryhawthorne - 08-24-2013, 03:23 PM
RE: Wireless RP-2 governor? - by Skip - 08-24-2013, 04:49 PM
RE: Wireless RP-2 governor? - by jerryhawthorne - 08-24-2013, 05:47 PM
RE: Wireless RP-2 governor? - by morzh - 08-24-2013, 06:54 PM
RE: Wireless RP-2 governor? - by jerryhawthorne - 08-24-2013, 08:17 PM
RE: Wireless RP-2 governor? - by morzh - 08-24-2013, 09:57 PM
RE: Wireless RP-2 governor? - by codefox1 - 08-27-2013, 07:06 PM
RE: Wireless RP-2 governor? - by BrendaAnnD - 08-27-2013, 10:02 PM
RE: Wireless RP-2 governor? - by codefox1 - 08-27-2013, 10:42 PM
RE: Wireless RP-2 governor? - by morzh - 08-27-2013, 11:19 PM
RE: Wireless RP-2 governor? - by BrendaAnnD - 08-28-2013, 12:16 AM
RE: Wireless RP-2 governor? - by BrendaAnnD - 08-28-2013, 12:17 AM
New member
Philco 630csx power cord
New member
There are currently 4004 online users. [Complete List]
» 3 Member(s) | 4001 Guest(s)
