Finally finished my 116
[Image: http://[URL=http://s831.photobucket.com/...592a10.jpg][/URL][/img]
[img][Image: http://i831.photobucket.com/albums/zz235...b7267c.jpg][/img]
Not perfect, but it came out pretty well. I wish I could find the before pictures but it had the typical badly flaking sides and top, ripped grille cloth, etc.
Steve Chambers
Finally finished my 116 - by Steve Chambers - 08-24-2013, 05:02 PM
RE: Finally finished my 116 - by Ron Ramirez - 08-24-2013, 05:33 PM
RE: Finally finished my 116 - by Jamie - 08-24-2013, 05:38 PM
RE: Finally finished my 116 - by Eric T - 08-24-2013, 06:28 PM
RE: Finally finished my 116 - by Bill Kinghorn - 08-24-2013, 07:41 PM
RE: Finally finished my 116 - by Paul Philco322 - 08-24-2013, 09:24 PM
RE: Finally finished my 116 - by Gene Pederson - 08-24-2013, 09:42 PM
RE: Finally finished my 116 - by TimC - 08-25-2013, 07:53 PM
RE: Finally finished my 116 - by Ron Ramirez - 08-25-2013, 08:25 PM
RE: Finally finished my 116 - by TimC - 08-25-2013, 08:47 PM
RE: Finally finished my 116 - by EricS - 08-27-2013, 09:04 AM
RE: Finally finished my 116 - by audiomagnate - 08-27-2013, 10:15 AM
RE: Finally finished my 116 - by Joeztech - 11-08-2013, 07:55 PM
RE: Finally finished my 116 - by PhilcoJohn - 11-08-2013, 08:28 PM
RE: Finally finished my 116 - by Jayce - 11-08-2013, 11:50 PM
There are currently 5810 online users. [Complete List]
» 2 Member(s) | 5808 Guest(s)
