49-900 Hippo
Found this Hippo on Friday. Cabinet is excellent shape, no chips, scruffs, cracks. Excellent looking. But tag stated " Not Working" but for $18.00, hey Icon_smile. Invetigating, found 7C6 doesn't sit tight in it's socket, will replace the socket. Upon investigating futher, I found a shorting wire, ( for lack of better term ) laying unattached between pin 2 & 5 on the 7C6. This is a stiff wire about diameter of a resistor lead, just lying there. I can't find anything on the schematic. I can't noticed any place where it looks like it broke off. I'm attaching a picture. Pic has tip on pen pointing to this wire. Should I just pull the wire out ? When I replace the socket, I don't want to rewire the 7C6 and find out latter this shorting wire is needed. Any ideas.
Thanks everyone.
http://www.nostalgiaair.org/Resources/669/M0013669.htm
Mike
49-900 Hippo - by mcars - 08-25-2013, 08:57 AM
RE: 49-900 Hippo - by vinzer - 08-25-2013, 04:36 PM
RE: 49-900 Hippo - by mcars - 08-25-2013, 06:22 PM
RE: 49-900 Hippo - by mcars - 08-25-2013, 06:31 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2009 online users. [Complete List]
» 4 Member(s) | 2005 Guest(s)
AvatarAvatarAvatarAvatar
