FM alignment
Whatever, pretty reliable inexpensive frequency counters are available to check the accuracy of aging signal generators, which always benefit from a recap/recarb job and should be left on for at least a half hour to stabilize, and of course be very careful about grounding. I have changed a lot of such old test stuff to 3 prong plugs and know my bench is wired properly. I do use isolation transformers where appropriate, so it's been a while since I was last knocked on my **s.
FM alignment - by Eric Adams - 08-25-2013, 05:10 PM
RE: FM alignment - by Mondial - 08-25-2013, 09:53 PM
RE: FM alignment - by Eric Adams - 08-25-2013, 10:05 PM
RE: FM alignment - by Eric Adams - 08-25-2013, 10:19 PM
RE: FM alignment - by Mondial - 08-25-2013, 10:32 PM
RE: FM alignment - by Eric Adams - 08-25-2013, 10:39 PM
RE: FM alignment - by Mondial - 08-25-2013, 10:52 PM
RE: FM alignment - by codefox1 - 08-25-2013, 11:31 PM
RE: FM alignment - by Eric Adams - 08-26-2013, 01:16 AM
RE: FM alignment - by Eric Adams - 08-27-2013, 09:23 AM
RE: FM alignment - by BrendaAnnD - 08-27-2013, 11:52 AM
RE: FM alignment - by Eric Adams - 08-27-2013, 01:05 PM
RE: FM alignment - by exray - 08-27-2013, 07:08 PM
RE: FM alignment - by Eric Adams - 08-27-2013, 09:01 PM
RE: FM alignment - by exray - 08-27-2013, 09:28 PM
RE: FM alignment - by Mondial - 08-27-2013, 09:39 PM
RE: FM alignment - by Eric Adams - 08-27-2013, 09:53 PM
RE: FM alignment - by Eric Adams - 08-29-2013, 08:45 PM
RE: FM alignment - by Mondial - 08-29-2013, 09:00 PM
RE: FM alignment - by Eric Adams - 08-29-2013, 09:09 PM
RE: FM alignment - by Eric Adams - 09-01-2013, 09:24 PM
RE: FM alignment - by Mondial - 09-01-2013, 10:01 PM
RE: FM alignment - by Eric Adams - 09-02-2013, 12:10 AM
RE: FM alignment - by BrendaAnnD - 09-02-2013, 04:10 AM
RE: FM alignment - by Eric Adams - 09-02-2013, 09:20 AM
RE: FM alignment - by Mondial - 09-02-2013, 01:44 PM
RE: FM alignment - by Eric Adams - 09-02-2013, 06:14 PM
RE: FM alignment - by Mondial - 09-02-2013, 07:24 PM
RE: FM alignment - by Eric Adams - 09-02-2013, 08:08 PM
RE: FM alignment - by Mondial - 09-02-2013, 08:42 PM
RE: FM alignment - by Eric Adams - 09-03-2013, 01:09 AM
RE: FM alignment - by Mondial - 09-03-2013, 11:16 AM
RE: FM alignment - by Eric Adams - 09-03-2013, 11:36 AM
New member
Philco 630csx power cord
New member
There are currently 4015 online users. [Complete List]
» 3 Member(s) | 4012 Guest(s)
