Bakelite scratch repair
I know this has been discussed before, but I thought I would share something I found that really works.
For scratches in Bakelite I found that Turtle Wax headlight restorer really works. It is a kit that comes with different grades of sanding pads, a cleaner and compound for polishing.
After removing the scratches I polish with car wax and it looks great.
You can get it at any auto parts store.
Eric
The Villages, FL
Bakelite scratch repair - by Eric Adams - 08-26-2013, 11:53 AM
RE: Bakelite scratch repair - by klondike98 - 08-26-2013, 12:09 PM
RE: Bakelite scratch repair - by Jamie - 08-26-2013, 02:00 PM
RE: Bakelite scratch repair - by Eric Adams - 08-26-2013, 07:04 PM
RE: Bakelite scratch repair - by Paul Philco322 - 08-27-2013, 08:24 PM
RE: Bakelite scratch repair - by Chuck Schwark - 08-28-2013, 09:19 AM
There are currently 9740 online users. [Complete List]
» 1 Member(s) | 9739 Guest(s)
