Need help restoring my 40-180 - SUCCESS
Hi All;
EricS, first welcome to this restoration part of the group..
The Part in Your second picture is a Coil, which May be Bad, Can't tell from the picture, but the crack doesn't look good..
Second, most Round Paper Caps can be restuffed, as what is available now days is much smaller in size.. The Square Retangular Brown objects are Mica Caps, and usually don't need to be replaced, unless they are in a high voltage circuit and even then most of the time they are ok.. But they should be check like the rest of the Caps..
Replace ALL Electrolitic Caps before Power is applied and All paper caps need to be replaced..
THANK YOU Marty
RE: Need help restoring my 40-180 - by marty - 08-26-2013, 02:12 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 02:33 PM
RE: Need help restoring my 40-180 - by klondike98 - 08-26-2013, 02:42 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 02:48 PM
RE: Need help restoring my 40-180 - by marty - 08-26-2013, 03:04 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 09:46 PM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 08:50 AM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 10:08 AM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 10:56 AM
RE: Need help restoring my 40-180 - by Jamie - 08-27-2013, 03:16 PM
RE: Need help restoring my 40-180 - by codefox1 - 08-27-2013, 06:25 PM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 07:43 PM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 08:55 PM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 10:45 PM
RE: Need help restoring my 40-180 - by EricS - 08-28-2013, 06:53 PM
RE: Need help restoring my 40-180 - by marty - 08-28-2013, 07:00 PM
RE: Need help restoring my 40-180 - by Raleigh - 08-28-2013, 07:37 PM
RE: Need help restoring my 40-180 - by EricS - 08-29-2013, 09:47 PM
RE: Need help restoring my 40-180 - by marty - 08-29-2013, 10:23 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 08:33 PM
RE: Need help restoring my 40-180 - by TA Forbes - 09-08-2013, 08:52 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 08:58 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 09:44 PM
RE: Need help restoring my 40-180 - by EricS - 09-09-2013, 08:29 AM
RE: Need help restoring my 40-180 - by morzh - 09-11-2013, 10:22 PM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-12-2013, 12:35 AM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-13-2013, 04:51 AM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-13-2013, 12:19 PM
RE: Need help restoring my 40-180 - by EricS - 09-20-2013, 11:41 PM
RE: Need help restoring my 40-180 - by EricS - 10-11-2013, 07:32 PM
RE: Need help restoring my 40-180 - by Jamie - 10-11-2013, 08:00 PM
RE: Need help restoring my 40-180 - by EricS - 10-13-2013, 07:25 PM
RE: Need help restoring my 40-180 - by EricS - 10-23-2013, 09:28 PM
RE: Need help restoring my 40-180 - by DeckApe - 10-28-2013, 06:11 PM
RE: Need help restoring my 40-180 - by EricS - 10-28-2013, 10:17 PM
RE: Need help restoring my 40-180 - by DeckApe - 11-21-2013, 01:19 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 09:04 AM
RE: Need help restoring my 40-180 - by murf - 08-10-2014, 09:41 AM
RE: Need help restoring my 40-180 - by murf - 08-10-2014, 09:57 AM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 11:51 AM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 04:09 PM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 04:13 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 10:10 PM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 10:18 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 11:14 PM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 08:32 AM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 09:37 AM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 02:54 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 03:06 PM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 03:58 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 04:09 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 04:13 PM
RE: Need help restoring my 40-180 - by EricS - 08-21-2014, 09:17 PM
RE: Need help restoring my 40-180 - by morzh - 08-21-2014, 09:40 PM
RE: Need help restoring my 40-180 - by EricS - 08-21-2014, 10:49 PM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 08:33 AM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 08:50 AM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 10:51 AM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 06:48 PM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 07:11 PM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 10:37 PM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 10:58 PM
RE: Need help restoring my 40-180 - by EricS - 08-25-2014, 09:01 PM
RE: Need help restoring my 40-180 - by murf - 08-25-2014, 09:48 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2014, 12:51 PM
RE: Need help restoring my 40-180 - by EricS - 08-28-2014, 09:59 PM
Users browsing this thread: 16 Guest(s)
There are currently 10286 online users. [Complete List]
» 3 Member(s) | 10283 Guest(s)
