Need help restoring my 40-180 - SUCCESS
City: Sedona, AZ/Placentia/CA
Eric, for a discussion on dial string take a look at this discussion.
http://philcoradio.com/phorum/showthread.php?tid=7332
For the dial pointer, post on the want to buy sub forum here, no telling, someone might have a scrap chassis. If not a picture of one might lead to you fabricating one.
Jerry
RE: Need help restoring my 40-180 - by jerryhawthorne - 08-26-2013, 10:27 PM
Users browsing this thread: 18 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9944 online users. [Complete List] » 3 Member(s) | 9941 Guest(s)
