Need help restoring my 40-180 - SUCCESS
City: Kentucky
If you guys need dial pointers, I've got two extra ones.. One is from a 46-1226 and the other is from a 46-1209. They aren't the same part number as yours, but the dials look very similar and you might be able to make them work. If you are interested, shoot me a PM. They are free if you want them.
RE: Need help restoring my 40-180 - by Jamie - 08-27-2013, 03:16 PM
Users browsing this thread: 20 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9732 online users. [Complete List] » 3 Member(s) | 9729 Guest(s)
