Bakelite scratch repair
I use Excaliber car polish - red and black can.
Chuck
Bakelite scratch repair - by Eric Adams - 08-26-2013, 11:53 AM
RE: Bakelite scratch repair - by klondike98 - 08-26-2013, 12:09 PM
RE: Bakelite scratch repair - by Jamie - 08-26-2013, 02:00 PM
RE: Bakelite scratch repair - by Eric Adams - 08-26-2013, 07:04 PM
RE: Bakelite scratch repair - by Paul Philco322 - 08-27-2013, 08:24 PM
RE: Bakelite scratch repair - by Chuck Schwark - 08-28-2013, 09:19 AM
There are currently 9489 online users. [Complete List]
» 2 Member(s) | 9487 Guest(s)
