Need help restoring my 40-180 - SUCCESS
Threads: 27
City: Boulder, Colorado
Hi All;
What I have found is one of two possibilities, one is it is a later replacement and the number has changed or two that the value is the same, such as .01, but the voltage rating is different 100 Volt vs, 250 volts for instance..
On my Philco 34 one of the .01 had been replaced with a later part same value, different part number, If I remember correctly the rating was different..
THANK YOU Marty
RE: Need help restoring my 40-180 - by marty - 08-28-2013, 07:00 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 5434 online users. [Complete List] » 1 Member(s) | 5433 Guest(s)
