Zenith 9S-262 and Philco 18 reception differences
Good to know.
Hadn't tried that vertical hanging wire on the Z yet - I am battling 37-116 dial assy. (Although I did have it in there first but then I noticed that internal antenna and connected it. And now I don't remember how the long wire behaved...maybe it was better and maybe I did not try it when it was noisy.....)
Plus other headaches that are many Icon_smile
Que dolor de cabeza!
There are currently 7369 online users. [Complete List]
» 2 Member(s) | 7367 Guest(s)
