37-620 Plate Resistor?
That resistor looks like a decoupling resistor, used to isolate the power supply of the IF stage from the converter and RF stages. Sometimes if B+ power is applied to all stages from the same source, you may get instability or oscillations due to the common power source. The resistor, together with a bypass cap serves to filter the supply and isolate the stages from each other preventing the problem.
Most likely, the 10K value on the schematic was a typo, all to common on the Philco schematics. The plates of the 6K7 and 6A8 probably draw about 10 mA total, so there would be a voltage drop of 10 volts or so across 1K which seems reasonable. A 10K would give 100V of drop which would clearly be excessive.
37-620 Plate Resistor? - by Vic Gibson - 08-30-2013, 09:21 AM
RE: 37-620 Plate Resistor? - by Mondial - 08-30-2013, 03:19 PM
RE: 37-620 Plate Resistor? - by Arran - 08-30-2013, 11:01 PM
RE: 37-620 Plate Resistor? - by Vic Gibson - 08-31-2013, 09:54 AM
RE: 37-620 Plate Resistor? - by codefox1 - 08-31-2013, 10:39 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4013 online users. [Complete List]
» 1 Member(s) | 4012 Guest(s)
