Restoring a 39-7
No bakelite capacitors from what I see. Two large "cans" for electrolytic. Some tubular capacitors that are polarized (at least that's what the black stripe implies to me), a silver-mica capacitor - that's about it. I'm trying to determine if replacing the tubular caps with a mylar film capacitor is OK.
Restoring a 39-7 - by rworne - 08-15-2013, 10:34 AM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:18 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 03:27 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:34 PM
RE: Restoring a 39-7 - by BrendaAnnD - 08-30-2013, 05:13 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 05:22 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:05 PM
RE: Restoring a 39-7 - by morzh - 08-30-2013, 06:17 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 06:29 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:52 PM
RE: Restoring a 39-7 - by Arran - 08-30-2013, 10:42 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 12:32 AM
RE: Restoring a 39-7 - by Jamie - 08-31-2013, 02:36 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 03:25 PM
RE: Restoring a 39-7 - by hunter2115 - 09-05-2013, 09:31 PM
RE: Restoring a 39-7 - by morzh - 09-05-2013, 09:38 PM
RE: Restoring a 39-7 - by rworne - 09-05-2013, 11:12 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 09:49 AM
RE: Restoring a 39-7 - by Mondial - 10-22-2013, 09:54 AM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 10:14 AM
RE: Restoring a 39-7 - by Radioroslyn - 10-22-2013, 05:53 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 08:28 PM
There are currently 8899 online users. [Complete List]
» 1 Member(s) | 8898 Guest(s)
