37-620 Plate Resistor?
When they install a resistor in the plate circuit of a tube a lot of it has to do with the potential between elements. Since this is used in the plate circuit of the 6A8 convertor tube I would replace it with one of an identical value, Philco was not in the habit of adding parts without a reason.
37-620 Plate Resistor? - by Vic Gibson - 08-30-2013, 09:21 AM
RE: 37-620 Plate Resistor? - by Mondial - 08-30-2013, 03:19 PM
RE: 37-620 Plate Resistor? - by Arran - 08-30-2013, 11:01 PM
RE: 37-620 Plate Resistor? - by Vic Gibson - 08-31-2013, 09:54 AM
RE: 37-620 Plate Resistor? - by codefox1 - 08-31-2013, 10:39 AM
New member
Philco 630csx power cord
New member
There are currently 3295 online users. [Complete List]
» 5 Member(s) | 3290 Guest(s)
AvatarAvatarAvatarAvatar
