37-620 Plate Resistor?
Agree, and beware if you are measuring voltages with a modern digit al mewter or even a VTVM, either of which will present little or no load. Ancient meters presented a significant load and so readings were guestimates at best.
Replace all the little carbon resistors along with the electrolytic and tubular capacitors.
Makes a huge difference in the end for safety, reliability, and longevity.
Up to you!
37-620 Plate Resistor? - by Vic Gibson - 08-30-2013, 09:21 AM
RE: 37-620 Plate Resistor? - by Mondial - 08-30-2013, 03:19 PM
RE: 37-620 Plate Resistor? - by Arran - 08-30-2013, 11:01 PM
RE: 37-620 Plate Resistor? - by Vic Gibson - 08-31-2013, 09:54 AM
RE: 37-620 Plate Resistor? - by codefox1 - 08-31-2013, 10:39 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2295 online users. [Complete List]
» 3 Member(s) | 2292 Guest(s)
