Model 19 Code 126 Question
Not at all, you will have to maintain electrical connection between speaker assembly and main chassis. Don't plug it in until all filter and tubular capacitors have been replaced. Chances are that tubes may be fine. GOod Luck.
Model 19 Code 126 Question - by PAradiogeek - 08-30-2013, 10:42 PM
RE: Model 19 Code 126 Question - by codefox1 - 08-31-2013, 10:52 AM
RE: Model 19 Code 126 Question - by morzh - 08-31-2013, 11:05 AM
RE: Model 19 Code 126 Question - by Jamie - 08-31-2013, 02:40 PM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-01-2013, 08:51 AM
RE: Model 19 Code 126 Question - by Ron Ramirez - 09-01-2013, 09:34 AM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-01-2013, 01:08 PM
RE: Model 19 Code 126 Question - by PAradiogeek - 09-01-2013, 06:19 PM
RE: Model 19 Code 126 Question - by Eric T - 09-01-2013, 11:10 PM
RE: Model 19 Code 126 Question - by BrendaAnnD - 09-01-2013, 11:36 PM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-02-2013, 09:53 AM
New member
Philco 630csx power cord
New member
There are currently 3929 online users. [Complete List]
» 2 Member(s) | 3927 Guest(s)
