Model 19 Code 126 Question
When you remove the speaker, do yourself a favor and cut out a piece of cardboard and tape it over the front of the speaker. It will keep the speaker protected while you work on things. Speaker cones are so fragile, it is very very easy to poke a hole in one.
Model 19 Code 126 Question - by PAradiogeek - 08-30-2013, 10:42 PM
RE: Model 19 Code 126 Question - by codefox1 - 08-31-2013, 10:52 AM
RE: Model 19 Code 126 Question - by morzh - 08-31-2013, 11:05 AM
RE: Model 19 Code 126 Question - by Jamie - 08-31-2013, 02:40 PM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-01-2013, 08:51 AM
RE: Model 19 Code 126 Question - by Ron Ramirez - 09-01-2013, 09:34 AM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-01-2013, 01:08 PM
RE: Model 19 Code 126 Question - by PAradiogeek - 09-01-2013, 06:19 PM
RE: Model 19 Code 126 Question - by Eric T - 09-01-2013, 11:10 PM
RE: Model 19 Code 126 Question - by BrendaAnnD - 09-01-2013, 11:36 PM
RE: Model 19 Code 126 Question - by Radioroslyn - 09-02-2013, 09:53 AM
New member
Philco 630csx power cord
New member
There are currently 2738 online users. [Complete List]
» 5 Member(s) | 2733 Guest(s)
AvatarAvatarAvatarAvatar
