Zenith 9S-262 and Philco 18 reception differences
Broadcasters are not immune to the same sort of problems we have. Bad connections on patch panels, noisy feeds, etc. plague them as well. Some speech I watched on CNN the other day had a ground loop in the mic circuit, and there was a goodly hum during the entire speech.
There are currently 10188 online users. [Complete List]
» 3 Member(s) | 10185 Guest(s)
