Two Questions
Marty
Here goes.
Go to radiomuseum, for example, and see the tube, say, 6J5G. This is one of the tubes i have on 37-116.
http://www.radiomuseum.org/tubes/tube_6j5g.html
Now the way they list the pins on the picture is from the key CLOCKWISE Mass(GND)-F(filament)-A(Anode for Plate)-Empty-Grid-Empty-Filament-K(cathode).
Now let's go to my 116 diagram which lists the tubes' voltages with the pics of the sockets with pins' names.
The note says "Socket Voltages Measured from Underside of Chassis).
This means the pins are lookled at FROM THE BOTTOM.
Now the 6J5G pins go CLOCKWISE (from the bottom):
(unmarked) - F - Plate - (empty) - Grid - (empty) - F - K(cathode).
Now as you can see the pins listed (on the Radio Museum Site) are looked at FROM THE BOTTOM and they are CLOCKWISE.
Same pinout is given here
http://www.r-type.org/pdfs/6j5-2.pdf
PS. Again, I do not know for all tubes whether the convention applies.
Two Questions - by marty - 08-25-2013, 10:04 AM
RE: Two Questions - by morzh - 08-25-2013, 11:15 AM
RE: Two Questions - by marty - 08-31-2013, 12:58 PM
RE: Two Questions - by marty - 08-31-2013, 08:41 PM
RE: Two Questions - by morzh - 08-31-2013, 09:51 PM
RE: Two Questions - by Mondial - 08-31-2013, 10:38 PM
RE: Two Questions - by marty - 08-31-2013, 11:25 PM
RE: Two Questions - by BrendaAnnD - 09-01-2013, 03:52 AM
RE: Two Questions - by BrendaAnnD - 09-01-2013, 04:01 AM
RE: Two Questions - by marty - 09-01-2013, 09:36 AM
New member
Philco 630csx power cord
New member
There are currently 4005 online users. [Complete List]
» 3 Member(s) | 4002 Guest(s)
