Philco 39-55 Mystery
Hi Robert,
I assume you have tried Mike Koste or David Frush on the Resources page?
If you're looking for a gear, you might want to try an R/C helicopter/ car site. Some have used R/C gears to substitute for their dial drives, etc. especially ones that were made of crumbling pot metal.
2 examples:
http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=EEE
http://www.robinsonracing.com/index.html
Of course a custom molded knob by Larry or someone would be best, but until then you might have to rig something up.
I don't know what the knob/gear looks like , so I can't recommend what I'd do. I am curious about what it looks like so if you can email a picture that would be great.
Good luck,
Gary.
Philco 39-55 Mystery - by Robert - 03-01-2008, 07:41 PM
[No subject] - by Ron Ramirez - 03-01-2008, 08:56 PM
[No subject] - by Robert - 03-02-2008, 04:25 PM
[No subject] - by gary rabbitt - 03-04-2008, 02:46 PM
[No subject] - by Robert - 03-09-2008, 08:30 PM
[No subject] - by Chuck Schwark - 03-09-2008, 11:10 PM
[No subject] - by Robert - 03-09-2008, 11:14 PM
Philco 39-55 - by Doug Houston - 03-27-2008, 11:36 PM
[No subject] - by Ron Ramirez - 03-28-2008, 07:28 PM
Philco 91 Tuning Condenser
There are currently 6404 online users. [Complete List]
» 2 Member(s) | 6402 Guest(s)
