Philco 84 restore
Restoring Model 84, Volume on/off switch is shot. any suggestions on replacement. I've been searching but can't seem to find one. It appears to be a 20k pot with 1.5 inch body and 1 inch shaft, fat flat. thanks
Philco 84 restore - by bbolton - 09-01-2013, 05:28 PM
RE: Philco 84 restore - by BrendaAnnD - 09-01-2013, 09:55 PM
RE: Philco 84 restore - by bbolton - 09-02-2013, 08:51 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
