37-116 - speaker and grommets' placement
The felt stripping I thought of proved to be very thin and narrower than I though.
I found felt weather stripping but this also was very thin and very wide.
So I found regular rubber foam weather stripping that was very close in both width and thickness, and it is self-adhesive so no gluing headache.....and the compression degree is about adequate, so it sticks out enough and gets some compression when the speaker is installed.
RE: 37-116 - speaker and grommets' placement - by morzh - 09-02-2013, 05:29 PM
New member
Philco 630csx power cord
New member
There are currently 2569 online users. [Complete List]
» 5 Member(s) | 2564 Guest(s)
AvatarAvatarAvatarAvatar
