Restoring my 37-116. It plays now!
Threads: 562
Here are some photos.
Rubber grommets or whatever you call them plus one pic of the speaker mounted.
All grommets
Closeup 1
Closeup 2
Closeup3
Speaker
RE: Restoring my 37-116. It plays now! - by morzh - 09-02-2013, 10:15 PM
Users browsing this thread: 30 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 8017 online users. [Complete List] » 2 Member(s) | 8015 Guest(s)
