Restoring my 37-116. It plays now!
Threads: 562
Yes I have a new bushing on the tuning cap - bought it from the "Renovated Radios". Along with some other spacers...maybe they will fit.
Those large silicon bushings are surprisingly soft. I wonder if they were in fact replaced at some point.
Question: the fact that all those bushings/grommets/spacers were on the volume / On switch shafts, it does not really mean that some actually go there, does it?
RE: Restoring my 37-116. It plays now! - by morzh - 09-03-2013, 10:06 AM
Users browsing this thread: 46 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
