Manual de radio zeniht modelo 765
Hello friends:
I'm buying a radio Model 765 zeniht bad that does not work I have seen that has broken a valve per photo I would like if someone has the manual handling of the radio and if someone also has the outline of the radio will be grateful as they I would like to restore. The purchase of the radio will cost me 350 euros.
Manual de radio zeniht modelo 765 - by locuspiolin - 09-03-2013, 11:12 AM
There are currently 5574 online users. [Complete List]
» 5 Member(s) | 5569 Guest(s)
AvatarAvatarAvatarAvatar
