Philco T9
I will do the alignment and repair since there's no one closer. It will need to be shipped to Colorado. Is the radio complete?
Don
Philco T9 - by Guest - 07-16-2007, 08:54 AM
[No subject] - by batterymaker - 07-27-2007, 10:56 PM
[No subject] - by Ron Ramirez - 07-28-2007, 12:55 PM
Copy of Schematics - by Guest - 07-29-2007, 08:56 PM
[No subject] - by Guest - 07-29-2007, 08:58 PM
[No subject] - by batterymaker - 08-07-2007, 09:49 AM
[No subject] - by Guest - 08-07-2007, 03:35 PM
[No subject] - by Don Lind - 08-08-2007, 12:54 PM
Philco T9 - by Guest - 08-09-2007, 11:13 AM
[No subject] - by Don Lind - 08-09-2007, 03:38 PM
[No subject] - by batterymaker - 08-10-2007, 09:33 AM
Picture - by Guest - 08-10-2007, 11:07 AM
[No subject] - by Don Lind - 08-11-2007, 05:04 PM
Repair Philco T9 - by Guest - 09-03-2007, 09:43 AM
[No subject] - by Guest - 03-06-2008, 09:59 AM
[No subject] - by Don Lind - 03-06-2008, 12:47 PM
[No subject] - by Guest - 03-07-2008, 10:30 AM
Philco 91 Tuning Condenser
There are currently 10362 online users. [Complete List]
» 1 Member(s) | 10361 Guest(s)
