40-190 chipped veneer
I'm a new guy here, but +1 on the recommendation for Howard Restore-A-Finish. Works quickly and easily, but stinks up the place - be sure to use it outside! I wiped it on with a soft cloth and then just let it dry.
[Image: http://www.facstaff.bucknell.edu/esantan...arison.jpg]
40-190 chipped veneer - by fossilexpress - 09-02-2013, 10:07 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 08:08 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 12:33 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 01:31 PM
RE: 40-190 chipped veneer - by EricS - 09-03-2013, 02:04 PM
RE: 40-190 chipped veneer - by Arran - 09-03-2013, 10:11 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 10:18 PM
RE: 40-190 chipped veneer - by codefox1 - 09-04-2013, 12:00 PM
RE: 40-190 chipped veneer - by Jamie - 09-05-2013, 11:56 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 08:31 PM
RE: 40-190 chipped veneer - by EricS - 09-05-2013, 11:14 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 11:36 PM
RE: 40-190 chipped veneer - by Arran - 09-06-2013, 01:27 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-15-2013, 11:42 PM
RE: 40-190 chipped veneer - by Jamie - 09-16-2013, 07:10 AM
RE: 40-190 chipped veneer - by EricS - 09-16-2013, 09:51 PM
RE: 40-190 chipped veneer - by EricS - 09-18-2013, 09:22 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-19-2013, 12:29 AM
RE: 40-190 chipped veneer - by EricS - 09-19-2013, 07:18 PM
There are currently 6455 online users. [Complete List]
» 1 Member(s) | 6454 Guest(s)
