Advice for restoring 38-12
Hi
Odd that your Rider's does not give specs for the field coil? Usually Rider merely copied the service bulletins provided to him by Philco, and the bulletin for Model 38-12 shows a field coil of 1500 ohms.
Specs for the power transformer, per 1941 Philco parts catalog:
High voltage secondary: 516 volts center-tapped, 50 mA DC
Filament winding: 6.3 volts @ 2A
Specs for the audio output transformer, per 1946 Philco Quick Selector Parts Directory:
Primary impedance 8000 ohms; secondary impedance 3.5 ohms; 3 watts; turns ratio 44:1.
You should seriously consider buying a copy of the factory service info from Chuck; he not only supplies a copy of the original Philco service bulletin, but also an extra-large copy of the schematic, and includes any pertinent changes.
http://www.philcorepairbench.com/schematics.htm
MUCH better info than found in Riders, and at a reasonable price.
Advice for restoring 38-12 - by Guest - 03-06-2008, 09:25 PM
RE: Advice for restoring 38-12 - by Chuck Schwark - 04-21-2015, 09:09 AM
[No subject] - by Ron Ramirez - 03-07-2008, 12:47 AM
Thanks - another question - by Guest - 03-08-2008, 09:07 PM
[No subject] - by Ron Ramirez - 03-09-2008, 08:50 AM
[No subject] - by TonyJSenior - 03-10-2008, 06:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
