  • 1 Vote(s) - 5 Average
filter choke
Typically specs aren't real important. The inductance you can go higher but not lower same with the current. Resistance isn't very important. If you can stay within 100-150 ohms of original
filter choke - by raydog - 09-03-2013, 06:33 PM
RE: filter choke - by Radioroslyn - 09-03-2013, 07:37 PM
RE: filter choke - by morzh - 09-03-2013, 09:30 PM
New member
Philco 630csx power cord
New member
There are currently 4076 online users. [Complete List]
» 1 Member(s) | 4075 Guest(s)
