Restoring my 37-116. It plays now!
Threads: 562
I put all the photos here Monday, those are the only ones I have.
I was told also the some of them go on other shafts to prevent light from the bulbs from leaking through the front panel.
RE: Restoring my 37-116. It plays now! - by morzh - 09-04-2013, 07:32 AM
Users browsing this thread: 17 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 5674 online users. [Complete List] » 1 Member(s) | 5673 Guest(s)
