40-190 chipped veneer
I would use some artrist's oils (often you can scrounge a set of them for little or nothing) to fill the chipped areas with a very fine artist's bruch or "spotting" bruch from the old days, then a few coats of shellac as needed to overfill, and a very gentle buffing and paste wax.
Shellac sticks and touchup crayons were often used for delivery screwups too, but not so great long term.
40-190 chipped veneer - by fossilexpress - 09-02-2013, 10:07 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 08:08 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 12:33 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 01:31 PM
RE: 40-190 chipped veneer - by EricS - 09-03-2013, 02:04 PM
RE: 40-190 chipped veneer - by Arran - 09-03-2013, 10:11 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 10:18 PM
RE: 40-190 chipped veneer - by codefox1 - 09-04-2013, 12:00 PM
RE: 40-190 chipped veneer - by Jamie - 09-05-2013, 11:56 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 08:31 PM
RE: 40-190 chipped veneer - by EricS - 09-05-2013, 11:14 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 11:36 PM
RE: 40-190 chipped veneer - by Arran - 09-06-2013, 01:27 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-15-2013, 11:42 PM
RE: 40-190 chipped veneer - by Jamie - 09-16-2013, 07:10 AM
RE: 40-190 chipped veneer - by EricS - 09-16-2013, 09:51 PM
RE: 40-190 chipped veneer - by EricS - 09-18-2013, 09:22 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-19-2013, 12:29 AM
RE: 40-190 chipped veneer - by EricS - 09-19-2013, 07:18 PM
