42-1008 power transformer
I rechecked all the wires from the transformer, # 32-8129, which is the correct original (run 122) per schematic and per the # engraved on the top of the transformer. There is definitely a wire going to one of the #41 output tubes, and this area has a wire that travels over to a similar pin area on the other 41 tube, but there is only one wire going from the transformer to this area. It appears to be a black wire. The other rectifier wires previously described are correct as Eric described.
Thanks for the input.
42-1008 power transformer - by davidff - 08-21-2013, 10:22 AM
RE: 42-1008 power transformer - by Jim Dutridge - 08-21-2013, 11:37 AM
RE: 42-1008 power transformer - by davidff - 08-26-2013, 10:08 AM
RE: 42-1008 power transformer - by BrendaAnnD - 08-26-2013, 02:57 PM
RE: 42-1008 power transformer - by codefox1 - 08-26-2013, 03:20 PM
RE: 42-1008 power transformer - by davidff - 09-03-2013, 07:43 AM
RE: 42-1008 power transformer - by Eric T - 09-03-2013, 07:39 PM
RE: 42-1008 power transformer - by Eric T - 09-03-2013, 11:08 PM
RE: 42-1008 power transformer - by marty - 09-04-2013, 12:05 AM
RE: 42-1008 power transformer - by davidff - 09-04-2013, 05:41 PM
RE: 42-1008 power transformer - by Eric T - 09-04-2013, 10:34 PM
RE: 42-1008 power transformer - by davidff - 09-19-2013, 11:31 AM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 1661 online users. [Complete List]
» 5 Member(s) | 1656 Guest(s)
AvatarAvatarAvatarAvatar
