Philco 118x
49Stude63 Wrote:I have the 118MX version, nice radio well worth the money you spent on it.
I always thought it was worth it but if your photos indicate what's underneath all that nasty white paint, it looks like an enjoyable set.
73 de,
Gary/N9VU
Philco 118x - by n9vu - 02-28-2008, 12:04 AM
[No subject] - by Ron Ramirez - 02-28-2008, 12:14 AM
[No subject] - by n9vu - 02-28-2008, 12:20 AM
[No subject] - by n9vu - 03-01-2008, 07:39 PM
[No subject] - by 49Stude63 - 03-04-2008, 10:15 PM
[No subject] - by Fred R - 03-05-2008, 11:14 AM
[No subject] - by n9vu - 03-08-2008, 03:45 PM
Philco 91 Tuning Condenser
