Old finish removal
Robert Wrote:I'm getting ready to refinish my 39-55 Mystery radio and I was wondering what is the best product to use with out taking the patina out of the wood.
Is Formby's a good choice or is there a better product. for the second question is, What did Philco use as a finish or is there a better product. inquiring minds want to know.
Bob.
Best stripper I've used (aside from Nina) is called Circa 1850. It's a gel type. Works fast and keeps the patina and grain filler. I use a cheap paint brush, brush a thick coat of gel on a small section (about a square foot), wait 5 minutes then remove the old finish using 00 steel wool. Repeat once or twice. Let dry, use 0000 steel wool on the cabinet prior to refinishing to smooth things out. As for the rest, Ron is right on the money. I prefer Mohawk as it is easily available and results are predictable.
Here's a radio I did for a neighbour. The trims are slightly darker than should be but that is was he prefers. All done with Mohawk lacquer in spray cans and Watco clear lacquer. I used two cans of Mohawk toning lacquer and 3 cans of Watco clear gloss. I did not have to fill the grain.
I took the picture before the correct grille cloth was replaced.
[Image: http://www.oldradioz.com/restoration/philco_650.jpg]
Syl
Old finish removal - by Robert - 03-02-2008, 04:40 PM
[No subject] - by Ron Ramirez - 03-02-2008, 08:02 PM
Re: Old finish removal - by Syl - 03-09-2008, 12:41 PM
[No subject] - by Robert - 03-09-2008, 08:32 PM
