37-630 speaker
The 610, 620 and 630 used a single ended 42 output tube.
The 37-610, 37-620 and 37-630 used a single ended 6F6G output tube.
42 and 6F6G have the same characteristics; the 6F6 is the octal version of the 42.
The output transformer may have a different part number, but the impedance should be the same.
37-630 speaker - by murf - 09-04-2013, 10:21 AM
RE: 37-630 speaker - by Radioroslyn - 09-04-2013, 10:26 PM
RE: 37-630 speaker - by murf - 09-04-2013, 11:15 PM
RE: 37-630 speaker - by Radioroslyn - 09-05-2013, 06:36 AM
RE: 37-630 speaker - by Ron Ramirez - 09-05-2013, 06:10 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
