Restoring my 37-116. It plays now!
Threads: 562
Thanks for the pics, very helpful.
Now after I looked at them I have an impression that those are the shipping contraptions Ron referred to and the bolts I have are from them, but this is probably why most folks do not see them - they had been tossed.
So maybe even though those can be used to hold the chassis they would be discarded in most cases.
What do you think?
RE: Restoring my 37-116. It plays now! - by morzh - 09-05-2013, 09:10 PM
Users browsing this thread: 37 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9763 online users. [Complete List] » 3 Member(s) | 9760 Guest(s)
