Restoring a 39-7
Thanks, I'll see if my local electronics shop has any...
Edit:
No luck. I have to go to the Internet. Any decent sources for these? I cannot locate any 6000pF caps, only 4700pF.
So what can I do? 4700 is enough, 10000 too much, or should I wire 3 2200's in parallel (I'd rather not tempt the fates of MTBF this way)?
Also there is one other silver mica capacitor in there - it's part 6A on the schematic. The problem is it's listed as a 20mfd device and there's no way this is 20mfd, it's just way too small. Elsewhere on the schematic it's listed as 20mmfd, which makes a lot more sense for this type of capacitor.
Restoring a 39-7 - by rworne - 08-15-2013, 10:34 AM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:18 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 03:27 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 03:34 PM
RE: Restoring a 39-7 - by BrendaAnnD - 08-30-2013, 05:13 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 05:22 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:05 PM
RE: Restoring a 39-7 - by morzh - 08-30-2013, 06:17 PM
RE: Restoring a 39-7 - by jerryhawthorne - 08-30-2013, 06:29 PM
RE: Restoring a 39-7 - by rworne - 08-30-2013, 06:52 PM
RE: Restoring a 39-7 - by Arran - 08-30-2013, 10:42 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 12:32 AM
RE: Restoring a 39-7 - by Jamie - 08-31-2013, 02:36 PM
RE: Restoring a 39-7 - by rworne - 08-31-2013, 03:25 PM
RE: Restoring a 39-7 - by hunter2115 - 09-05-2013, 09:31 PM
RE: Restoring a 39-7 - by morzh - 09-05-2013, 09:38 PM
RE: Restoring a 39-7 - by rworne - 09-05-2013, 11:12 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 09:49 AM
RE: Restoring a 39-7 - by Mondial - 10-22-2013, 09:54 AM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 10:14 AM
RE: Restoring a 39-7 - by Radioroslyn - 10-22-2013, 05:53 PM
RE: Restoring a 39-7 - by rworne - 10-22-2013, 08:28 PM
There are currently 9952 online users. [Complete List]
» 3 Member(s) | 9949 Guest(s)
