Philco 39-55 Mystery
Thx for the info Gary, You have given me an idea.
Try to replace the gear with a new metal one I just have to find the right diameter and teeth.
Question? do you know how the dial on the Mystery control comes off?
I don't want to break anything at this point.
Bob
Philco 39-55 Mystery - by Robert - 03-01-2008, 07:41 PM
[No subject] - by Ron Ramirez - 03-01-2008, 08:56 PM
[No subject] - by Robert - 03-02-2008, 04:25 PM
[No subject] - by gary rabbitt - 03-04-2008, 02:46 PM
[No subject] - by Robert - 03-09-2008, 08:30 PM
[No subject] - by Chuck Schwark - 03-09-2008, 11:10 PM
[No subject] - by Robert - 03-09-2008, 11:14 PM
Philco 39-55 - by Doug Houston - 03-27-2008, 11:36 PM
[No subject] - by Ron Ramirez - 03-28-2008, 07:28 PM
Philco 91 Tuning Condenser
