Need some ideas on a fix..
Did one a few years ago and yes, the faucet washer did the trick. As I recall in needed a couple layers of heat shrink over the bare shaft to build up the OD such that the washer would press on.
Jerry
Need some ideas on a fix.. - by Jamie - 09-05-2013, 06:22 PM
RE: Need some ideas on a fix.. - by keithw - 09-05-2013, 06:48 PM
RE: Need some ideas on a fix.. - by Jamie - 09-05-2013, 06:56 PM
RE: Need some ideas on a fix.. - by w4rtc - 09-05-2013, 07:57 PM
RE: Need some ideas on a fix.. - by Jamie - 09-05-2013, 08:05 PM
RE: Need some ideas on a fix.. - by morzh - 09-05-2013, 11:26 PM
RE: Need some ideas on a fix.. - by Jamie - 09-06-2013, 04:17 AM
RE: Need some ideas on a fix.. - by BrendaAnnD - 09-06-2013, 08:17 AM
RE: Need some ideas on a fix.. - by jerryhawthorne - 09-06-2013, 02:01 PM
RE: Need some ideas on a fix.. - by Jamie - 09-06-2013, 02:32 PM
RE: Need some ideas on a fix.. - by codefox1 - 09-06-2013, 05:07 PM
There are currently 5765 online users. [Complete List]
» 2 Member(s) | 5763 Guest(s)
