Need some ideas on a fix..
I'll swing by the hardware store this weekend and grab an assortment of grommets and rubber washers. The leather is working fine, I'm just afraid it won't last long.
It's a real nice radio. Everything seems solid and designed to last. I had to search high and low to find a schematic. Delco went by United Motors, and that's where schematics are in the Riders. It was seriously out of alignment at first. It barely got one station in two places on the dial and that was it. Once it was aligned, it sure started to sing.
That's the original finish, with one coat of clear Mohawk applied. I also repainted the dark brown trim. Just flipped the grill cloth around. I wish I'd photographed it before I began to work on it. I thought for sure it would need to be stripped. There was white paint on the top, and 70 years of black grunge covering everything else. I think it may have been a shop radio in a garage. It always amazes me how well some of these clean up.
Thanks to everyone for the rubber grommet/washer ideas.
Need some ideas on a fix.. - by Jamie - 09-05-2013, 06:22 PM
RE: Need some ideas on a fix.. - by keithw - 09-05-2013, 06:48 PM
RE: Need some ideas on a fix.. - by Jamie - 09-05-2013, 06:56 PM
RE: Need some ideas on a fix.. - by w4rtc - 09-05-2013, 07:57 PM
RE: Need some ideas on a fix.. - by Jamie - 09-05-2013, 08:05 PM
RE: Need some ideas on a fix.. - by morzh - 09-05-2013, 11:26 PM
RE: Need some ideas on a fix.. - by Jamie - 09-06-2013, 04:17 AM
RE: Need some ideas on a fix.. - by BrendaAnnD - 09-06-2013, 08:17 AM
RE: Need some ideas on a fix.. - by Jamie - 09-06-2013, 02:32 PM
RE: Need some ideas on a fix.. - by codefox1 - 09-06-2013, 05:07 PM
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
