Advice for restoring 38-12
Another part you might want to check out is the oscillator transformer for an open winding. My set had an open winding and the parts set I bought had a bad one as well. Ended up putting a new winding on it and worked well after that. Had an open antenna coil as well and the parts set one was damaged and bought a universal replacement from AES for that.
Here is a link to some Philco documentation for that set:
http://www.audiophool.cjb.net/Misc/philco_38-12.djvu
You'll need a DJVU viewer to open them. I'd also recommend using Chuck as a source of schematics as his information is more complete than most you find posted on the net.
Advice for restoring 38-12 - by Guest - 03-06-2008, 09:25 PM
RE: Advice for restoring 38-12 - by Chuck Schwark - 04-21-2015, 09:09 AM
[No subject] - by Ron Ramirez - 03-07-2008, 12:47 AM
Thanks - another question - by Guest - 03-08-2008, 09:07 PM
[No subject] - by Ron Ramirez - 03-09-2008, 08:50 AM
[No subject] - by TonyJSenior - 03-10-2008, 06:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
