Quick and dirty (but extremely effective) longwire antenna
Too bad my landline connections are still live.
One thing to add about coax lead in- if it is connected from ANT to GND, the coax capacitance will be in parallel with the input tuning circuits and drastically reduce reception (been there, done that). However, is you use a simple ferrite ring transformer of perhaps 5- 10 turns wound bifilar, and connect that to the balanced input, the reception is outstanding! -Pete
Pete AI2V
Coax lead-in - by AI2V - 03-10-2008, 10:10 PM
[No subject] - by Ron Ramirez - 03-10-2008, 11:07 PM
[No subject] - by Jim Dutridge - 03-11-2008, 04:47 PM
[No subject] - by TonyJSenior - 03-11-2008, 05:26 PM
[No subject] - by Ron Ramirez - 03-11-2008, 08:18 PM
[No subject] - by TonyJSenior - 03-11-2008, 09:15 PM
[No subject] - by TonyJSenior - 03-11-2008, 09:20 PM
[No subject] - by Ron Ramirez - 03-12-2008, 06:45 PM
[No subject] - by planigan - 03-13-2008, 01:16 AM
[No subject] - by TonyJSenior - 03-13-2008, 10:36 AM
[No subject] - by planigan - 03-13-2008, 10:52 AM
Philco 91 Tuning Condenser
There are currently 8722 online users. [Complete List]
» 1 Member(s) | 8721 Guest(s)
