Cleaning speaker cloth?
Unfortunately, it's not that it "might" shrink some - because it will shrink some - so be prepared for that.
Cleaning speaker cloth? - by Tobymiles - 07-25-2013, 01:32 AM
RE: Cleaning speaker cloth? - by Arran - 07-25-2013, 06:36 AM
RE: Cleaning speaker cloth? - by Vic Gibson - 07-28-2013, 10:14 AM
RE: Cleaning speaker cloth? - by EricS - 09-06-2013, 09:53 PM
RE: Cleaning speaker cloth? - by codefox1 - 09-07-2013, 11:47 AM
RE: Cleaning speaker cloth? - by Ron Ramirez - 09-07-2013, 08:58 PM
RE: Cleaning speaker cloth? - by EricS - 09-08-2013, 07:48 PM
RE: Cleaning speaker cloth? - by morzh - 09-09-2013, 01:58 PM
RE: Cleaning speaker cloth? - by Eliot Ness - 09-09-2013, 06:34 PM
RE: Cleaning speaker cloth? - by klondike98 - 09-09-2013, 06:59 PM
RE: Cleaning speaker cloth? - by Eliot Ness - 09-10-2013, 09:48 AM
RE: Cleaning speaker cloth? - by Geoff - 09-11-2013, 01:35 PM
