Trying to clean knurled knobs from 37-116
Toothbrush and alcohol works for me. Bakelite is almost indestructible. Once you get them cleaned up, you can spritz them with some clear lacquer if you want to make them look brand new.
RE: Trying to clean knurled knobs from 37-116 - by Jamie - 09-08-2013, 03:22 PM
New member
Philco 630csx power cord
New member
There are currently 3944 online users. [Complete List]
» 1 Member(s) | 3943 Guest(s)
