Trying to clean knurled knobs from 37-116
I've had very good luck letting them soak in a heavy spray of furniture polish (Pledge). The grime seems to come right off with a toothbrush and the polish shines them up. Go-Jo or Goop should do well also, and any treatment might take more than one application. The sharpest thing I would try using as a last resort is something like a wood toothpick.
RE: Trying to clean knurled knobs from 37-116 - by Eliot Ness - 09-09-2013, 05:58 PM
New member
Philco 630csx power cord
New member
There are currently 3147 online users. [Complete List]
» 5 Member(s) | 3142 Guest(s)
AvatarAvatarAvatarAvatar
