Phico 52 volume control problem
Yes I understand that I'm looking at the bottom schematic which is the one for the model 51 and 52.
It does control the IF gain thru the volume control.
RE: Phico 52 volume control problem - by Arran - 09-09-2013, 09:27 PM
RE: Phico 52 volume control problem - by Radioroslyn - 09-09-2013, 09:55 PM
New member
Philco 630csx power cord
New member
There are currently 4078 online users. [Complete List]
» 1 Member(s) | 4077 Guest(s)
