Phico 52 volume control problem
Terry, I did study the schematic a little more and #34 is a bakelite with a 200 ohm and a cap, also labeled as #34. The radio did the same thing prior to restuff so I think I need to look a little longer along that line towards the IF. You have given me some ideas and thanks. I understand you are looking at the right schematic.
Jerry
PS Aaron sorry when I indicated you were looking at the 51, I should have said the 50. The 51 and 52 seem to be the same and both have a center tap at ground.
RE: Phico 52 volume control problem - by Arran - 09-09-2013, 09:27 PM
RE: Phico 52 volume control problem - by jerryhawthorne - 09-09-2013, 10:07 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4056 online users. [Complete List]
» 1 Member(s) | 4055 Guest(s)
