Threads: 562
Marty
You should've replaced all of them without trying to learn anything.
It is likely a cap that breaks down, maybe an interstage in the audio, say between the detector and the output amp.
or maybe a decoupling one.
But if you keep experimenting like this you may potentially lose your rectifier or a filter choke or a field coil...God know.
yes you do learn things by finding bad parts but the practice of replacing questionable parts in advance to me is unbeatable in the first place.
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 01:47 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 4525 online users. [Complete List] » 1 Member(s) | 4524 Guest(s)
